*realizeengineeringentity
Realize an engineering entity.
*realizeengineeringentity entity_type entity_id reserved
HyperMesh Tcl Modify Command
- entity_type
 - The type of engineering entity to realize.
 - reserved
 - Reserved for future use. Must be set to 0.
Realize the mass entity with ID 10:
*realizeengineeringentity masses 10 0
   # Handle error
}Version History
2017.2
