*mode
Sets the operations performed when a full-size plot is generated in a command file.
*mode type
HyperMesh Tcl Modify Command
- type
 - Defines the mode or operations performed when a full-size plot is generated from a command file.
To pause for 10 seconds after a full-size plot is performed, place the following command before the full-size plot request:
*mode(10)
None.
