*morphorganizedomainsplit
Splits edge domain at given node.
*morphorganizedomainsplit nptr domainpointer dptr
HyperMesh Tcl Modify Command
- node
 - ID of node.
 - dptr
 - ID of domain.
*morphorganizedomainsplit 12 32
      This command splits the given edge domain into two edge domains at the given node.
   # Handle error
