*weld
Creates a weld element between two nodes.
*weld independent dependent length systems movenode
HyperMesh Tcl Modify Command
independent
The independent node.
dependent
The dependent node.
length
The length of the weld.
systems
Determines if systems should be built at the end of the node (1 for yes, 0 for no).
movenode
Set to 1 to move the node perpendicular to the surface of the elements, otherwise 0.
To build a weld element between nodes 100 and 101 with length 1.0 and without systems being built at the ends of the weld element:
*weld(100,101,1.0,0,0)
None.
