*numbersmark
Places the entities in the mark on the numbers mark. This will display the ID of the entity.
*numbersmark entity type mar on
HyperMesh Tcl Modify Command
- entity type
 - The type of entity contained on the mark.
 - mark
 - The ID of the mark.
 - on
 - Determines whether the entities will be placed on the numbers mark or removed from the numbers mark (1 to put on, 0 to remove).
To place nodes 5, 6, and 7 on the numbers mark:
*createmark(nodes,1) 5 6 7
*numbersmark(nodes,1,1)
None.
