*penetrationcheck
Checks the given components for contact surface penetrations.
*penetrationcheck entity_type mark_id check_type
HyperMesh Tcl Modify Command
Checks the given components for contact surface penetrations. To release the memory after completion, use the command *penetrationcheckend.
A valid template must be loaded for the check to occur.
entity_type
The type of entity to check for penetration. Valid values are groups and elems.
mark_id
The ID of the mark containing the entities to check. Valid values are 1 and 2.
check_type
The type of penetration check to perform. Valid values are:
  • 0 - groups
  • 3 - elems only
To check the elements in group E2E for penetration:
*createmark groups 1 E2E
*penetrationcheck groups 1 0
   # Handle error
