Review links according to user options.
      *CE_ReviewLinks
        link_type mark_id operation_type string_array number_of_strings
          output_mark
      HyperMesh Tcl Modify Command
          - link_type
          - The type of link to review.
          - mark_id
          - The ID of the mark to review.  Valid values are 1 and 2.
          - operation_type
          - The string for the type of operation to be performed:
          - find
          - findattached
          - findbetween
          - hide
          - isolate
          - isolateonly
          - show
          - To operate on between links:
          - cebetween_hide
          - cebetween_isolate
          - cebetween_isolateonly
          - cebetween_show
          - string_array
          - A string array containing any additional input parameters, created using
              *createstringarray. This must be set to 1.
          - The strings are generally IDs/names/UIDs based on the
            link_rule.
                - consider_geom=<value>
                - Defines if geometry is also considered along with elements during
                  show/hide/isolate operations. Valid values are true and false.
                - consider_HAZ_elems=<value>
                - Defines if HAZ (Heat Affected Zone) elements should also be considered during
                  show/hide/isolate operations. The possible values are true and false.
                - find_twince_option=<value>
                - Find twin connectors according to:
                - 1 - Minimum two links
                - 2 - Exact links
                - filter_projection_entities=<value>
                - Filters links to the projection entities during show/hide/isolate operations,
                  according to following options which are possible values:
                - 0 - None
                - 1 - Projection components
                - 2 - Projection elements
                - 3 - Projection and attached elements
          - number_of_strings
          - Integer indicating the size (number of strings) in the string_array
            created using *createstringarray.
          - output_mark
          - The ID of the mark onto which reviewed entities are placed.  Valid values are 1 and
            2.
    Examples
      To isolate components with ID 2 and 4 with no overwritten user
        options:
*createmark components 1 component2 component4
*CE_ReviewConnectors components 1 isolate 1 0 2
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
