*lightswitch
Turns the lights on or off.
*lightswitch on plot
HyperMesh Tcl Modify Command
- on
 - A flag that indicates if the lights should be turned off (0) or on (1).
 - plot
 - A flag that indicates if the screen should be replotted after this command is executed.
To switch the lights off and replot the screen:
*lightswitch(0,1)
      To turn the lights back on, but leave the screen as-is (no refresh):
*lightswitch(1,0)
None.
