*loadcreatewithsystem
Creates a load (force, moment, pressure, or constraint) at a node or element defined in a local coordinate system.
*loadcreatewithsystem mark config type [comp1-6] system transformflag
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark containing the nodes or elements that will bear the load.
 - config
 - The load configuration.
 - type
 - Solver dependent types of the referenced load config.
- 1 - Force
 - 2 - Moment
 - 3 - Constraint
 - 4 - Pressure
 - 5 - Temperature
 - 6 - Nodal flux
 - 8 - Velocity
 - 9 - Acceleration
 - component 1-6
 - Components of the load being applied. When applying a force, the active components are 1, 2, and 3, which represent a force x, y, and z axis, respectively.
 - system
 - ID of the coordinate system to use.
 - transformflag
 -  Indicates which system supplies component values.
- 0 - If the component values are supplied in the global coordinate system.
 - 1 - If the component values are supplied in the local coordinate system.
To apply a force of magnitude 10.0 along the x axis of local system 4 to nodes 5 and 25:
*createmark(nodes,1) 5 25
*loadcreatewithsystem(1,1,1,10.0,0.0,0.0,0.0,0.0,0.0, 4,1)
      To apply a constraint of zero in the global 1, 3, 5 directions to nodes 12, 13, and 14, but have the constraint communicated to the solver in the local coordinate system with ID 4:
*createmark(nodes,1) 12 13 14
*loadcreatewithsystem(1,1,3,0.0,999999.0,0.0,999999.0,0.0,-999999.0, 4,0)
None.
