*CE_ConnectorTrimAdvanced
shortDescription
*CE_ConnectorTrimAdvanced style mark_id node_mark_id tolerance snap mode1 mode2
HyperMesh Tcl Modify Command
longDescription
- style
 - The style of connectors to edit. Valid values are area, seam and spot.
 - mark_id
 - The ID of the mark of connectors. Valid values are 1 and 2.
 - node_mark_id
 - The ID of the mark of nodes. Valid values are 1 and 2.
 - tolerance
 - The tolerance value used to snap the nodes to the point of spot connectors when snap is 1.
 - snap
 - 0 - Do not snap nodes to spot connectors
 - mode1
 - 0 - Split
 - mode2
 - 0 - None
Examples
*createmark connectors 1 101
*createmark nodes 1 1001
*CE_ConnectorTrimAdvanced spot 1 1 0.5 1 0 0*createmark connectors 1 102
*createmark nodes 1 1002
*CE_ConnectorTrimAdvanced seam 1 1 0.5 1 1 0Errors
   # Handle error
}Version History
2021
