*CE_ConnectorUpdateByCC
Updates connectors using a connector control or connector control default.
*CE_ConnectorUpdateByCC mark_id name entity_type
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of connectors. Valid values are 1 and 2.
name
The name of the connector control or connector control default to use.
entity_type
The type of entity to use. Valid values are connectorcontrol and connectorcontroldefault.
Examples
Update connectors 101, 102, 103 using the connector control named "my_acm":
*createmark connectors 1 101 102 103
*CE_FE_ConnectorUpdateByCC 1 "my_acm" connectorcontrol
   # Handle error
Version History
2021
