*filewriteentities
Saves a BINARY file with only the contents of selected modules/parts.
*filewriteentities entity_type mark_id filename reserved
HyperMesh Tcl Modify Command
Saves a BINARY file with only the contents of selected modules/parts. This is useful for shattering a large BINARY file into smaller ones.
- There can be only one module on the input mark. That module may have multiple children.
 - Only the entities listed below are saved, and all other entities are ignored:
- All components in the module hierarchy.
 - All elements in those components.
 - All nodes in those components.
 - Materials referred by those components.
 - Properties referred by those components.
 - Materials referred by those properties.
 - Components being exported must not be topologically connected to components in modules not part of the hierarchy being exported.
- entity_type
 - The entity type to export. Only supported for modules.
 - mark_id
 - The mark ID of modules. Valid values are 1 and 2. Only one module may be on the mark.
 - filename
 - The full name and ID of the file to write.
 - reserved
 - Reserved for future use. Must be set to 0.
*filewriteentities modules 1 C:/temp/shatter10.hm 0Errors
   # Handle error
}Version History
14.0
2019 - Geometry facets are now also saved.
