*CE_DetailSetDouble
Sets a double connector detail for a single connector.
*CE_DetailSetDouble connector_id detail_name double_value reserved force_storage
HyperMesh Tcl Modify Command
connector_id
The ID of connector to update.
detail_name
The name of the standard double detail, or user-defined double detail, to update. Standard double details include:
ce_appliedmass
The mass value to be applied.
Value ≥ 0
ce_areaconstthickness
The constant thickness (for area connectors).
Value ≥ 0
ce_aspect
Fail hexas with aspect ratio greater than this value.
Value ≥ 0
ce_bl_connection_ang
The maximum angle allowed between two shells for B connection.
Value ≥ 0
ce_bodylen
The bolt body length.
Value ≥ 0
ce_boltmaxdiameter
The maximum diameter to be considered a bolt hole.
Value ≥ 0
ce_boltmaxfeatureangle
The maximum feature angle to identify a solid bolt hole.
Value ≥ 0
ce_boltmindiameter
The minimum diameter to be considered a bolt hole.
Value ≥ 0
ce_boltminfeatureangle
The minimum feature angle to identify a solid bolt hole.
Value ≥ 0
ce_boltthread
The bolt thread length.
Value ≥ 0
ce_centered_quad_pos_tol
The quad position tolerance.
Value ≥ 0
ce_centered_quad_scale_tol
The quad scale tolerance.
Value ≥ 0
ce_centered_quad_size_tol
The quad size tolerance
Value ≥ 0
ce_centered_quad_translate_tol
The quad translate tolerance.
Value ≥ 0
ce_cylinder_diameter
Define cylinder using this value as diameter.
Value ≥ 0
ce_cylinder_diameter_factor
Define the cylinder using this value as a factor.
Value ≥ 0
ce_dia_factor
The cylinder bolt diameter factor.
Value ≥ 0
ce_diameter
The diameter required by the realization.
Value ≥ 0
ce_fe_capangle
The angle between an ending cap element face and shell edge.
Value ≥ 0
ce_fe_const_height
The hexa constant thickness.
Value ≥ 0
ce_fe_depth
The penta width.
Value ≥ 0
ce_fe_factor_a
The hexa thickness, by multiplying this value using the smallest shell thickness.
Value ≥ 0
ce_fe_factor_b
The hexa position, by adding this value using the half of the thickness.
Value ≥ 0
ce_fe_featureangle
The feature break angle for locating RBE3 nodes.
Value ≥ 0
ce_fe_hexa_to_washer_offset
The offset from the hexa boundary to the washer inner diameter.
Value ≥ 0
ce_fe_height
The quad position in the vertical direction.
Value ≥ 0
ce_fe_maint_gaps
The gap value between a hexa face and a shell.
Value ≥ 0
ce_fe_offsetangle
The angle between quad and vertical direction.
Value ≥ 0
ce_fe_rbe3radius
The radius defining the circular area for locating RBE3 nodes.
Value ≥ 0
ce_fe_runoffangle
The deviating angle of the quad next to an ending cap element.
Value ≥ 0
ce_fe_tapered_t_angle
The angle of the tapered T weld.
Value ≥ 0
ce_fe_tapered_t_d
The thickness of the tapered T weld.
Value ≥ 0
ce_fe_tapered_t_h
The height of the tapered T weld.
Value ≥ 0
ce_fe_tapered_t_h1
Value ≥ 0
ce_fe_tapered_t_h2
The width of the tapered T weld.
Value ≥ 0
ce_fe_width
The penta depth.
Value ≥ 0
ce_hexa_position_distance
Move hexa by this distance from default position.
Value ≥ 0
ce_jacobian
Fails hexas with Jacobian less than provided value.
Value ≥ 0
ce_l1
The cylinder bolt length for L1 direction.
Value ≥ 0
ce_l1d1
The cylinder bolt diameter for L1 direction.
Value ≥ 0
ce_l2
The cylinder bolt length for L2 direction.
Value ≥ 0
ce_l2d2
The cylinder bolt diameter for L2 direction.
Value ≥ 0
ce_lt_connection_ang
The minimum angle allowed between two shells for T connection.
Value ≥ 0
ce_new_diameter
The diameter value used for punching a new bolt hole during realization.
Value ≥ 0
ce_no_hole_diameter
The diameter value when there is no hole during realization.
Value ≥ 0
ce_normal_angle
The deviation angle allowed for normal projection.
Value ≥ 0
ce_offset
Line connector end offset value.
Value ≥ 0
ce_quad_size
The quad size for the quad transition.
Value ≥ 0
ce_seam_break_len
The break length before the next weld.
Value ≥ 0
ce_seam_elem_len
The hexa element length.
Value ≥ 0
ce_seam_discontinuity_lower_tol
The lower bound tolerance allowed by the weld length.
Value ≥ 0
ce_seam_discontinuity_upper_tol
The upper bound tolerance allowed by the weld length.
Value ≥ 0
ce_seam_weld_len
The weld length before the next break.
Value ≥ 0
ce_spacing
The spacing value for a line or seam connector.
Value ≥ 0
ce_tolerance
The tolerance value specified during connector FE realization.
Value ≥ 0
ce_washer_elem_size
The element size around a bolt hole.
Value ≥ 0
ce_washer_scale_1
The 1st washer's width using a scale of bolt radius.
Value ≥ 0
ce_washer_scale_2
The 2nd washer's width using a scale of bolt radius.
Value ≥ 0
ce_washer_width_1
The 1st washer's width using this value.
Value ≥ 0
ce_washer_width_2
The 2nd washer's width using this value.
Value ≥ 0
double_value
The double value to update for the detail.
reserved
Reserved for future use. Must be set to 0.
force_storage
0 - Do not store user-defined detail.
1 - Store user-defined detail.
Examples
To set the tolerance to 10.0 for connector 1:
*CE_DetailSetDouble 1 ce_tolerance 10.0 0 0
To set a user-defined double detail "test" to a value of 5.0 for connector 2:
*CE_DetailSetDouble 2 "test" 5.0 0 1
   # Handle error
