*positionmark
Positions a selection of entities in space.
*positionmark entity_type mark_id node1 node2 node3 node4 node5 node6
HyperMesh Tcl Modify Command
This command positions a selection of entities in space.
entity_type
The type of entity to position.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
node1-node6
The IDs of the nodes used to position the entities. The positioning attempts to align the first three nodes (1-3) to the second three nodes (4-6).
To position component wheel using nodes 10-15:
*createmark comps 1 wheel
*positionmark comps 1 10 11 12 13 14 15
   # Handle error
