*hwct_closelibrary
Closes a currently open library.
*hwct_closelibrary entity_type
HyperMesh Tcl Modify Command
entity_type
The type of connected library. Currently only supported for subsystems.
Examples
Close the currently connected subsystem library:
*hwct_closelibrary subsystems
   # Handle error
Version History
2020
