*AE_Realize
Realize attachments.
*AE_Realize mark_id options
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of attachments to realize. Vaild values are 1 and 2.
options
0 - Reacquire hole info while keeping any previous part/comp info
1 - Reacquire hole, part, and comp info (helpful after a part swap)
Examples
Realize all attachments in the model:
*createmark attachments 1 all
*AE_Realize 1 0
   # Handle error
Version History
2020
