*CE_ConnectorLineCombineWithCC
Combines multiple line connectors to a single line connector and assigns a connectorcontrol.
*CE_ConnectorLineCombineWithCC mark_id entity_type entity_mark_id entity_list_id ce_style num_links link_entity_type link_mark_id string_array number_of_strings cc_type cc_name
HyperMesh Tcl Modify Command
Combines multiple line connectors to a single line connector and assigns a connector control. In addition, the internal lines (within the connectors) are merged into a single internal line.
- mark_id
 - The ID of the mark of connectors. Valid values are 1 and 2.
 - entity_type
 - The entity type that specifies the location to create connectors. Valid values are lines.
 - entity_mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2. If specified, set entity_list_id as 0.
 - entity_list_id
 - The ID of the list containing the entities. Valid values are 1 and 2. If specified, set entity_mark_id as 0.
 - ce_style
 - The style of connectors to create. Valid values are apply_mass, area, bolt, seam, and spot.
 - num_links
 - The number of links to use.
 - link_entity_type
 - The type of entity to create links for. Valid values are:
 - link_mark_id
 - The ID of the mark of link entities. Valid values are 1 and 2.
 - string_array
 - The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
 - cc_type
 - The type of control to assign. Valid values are connectorcontrol and connectorcontroldefault.
 - cc_name
 - The name of the connectorcontrol/connectorcontroldefault to assign.
Examples
*CE_FE_CreateDCC 1
*CE_FE_CreateUCCFromDCC "connectorcontrol1" "plot_spot_template"
*createmark connectors 1 1 2
*createmark lines 1 3 4
*createmark comps 2 3 4
*createstringarray 9 "link_elems_geom=elems" "link_rule=now" "relink_rule=none" "tol_flag=1" "tol=99.0" "line_density=0" "line_spacing=5.000000" "line_offset=0.000000" "line_combine_option=combine_smooth"
*CE_ConnectorLineCombineWithCC 1 lines 1 1 spot 2 comps 2 1 9 connectorcontrols connectorcontrol1
   # Handle error
}Version History
2021
