*CE_SetGlobalSharedEntitySettings
Set the global shared entity management settings.
*CE_SetGlobalSharedEntitySettings setting value
HyperMesh Tcl Modify Command
- setting
 - The name of the setting to update.
- auto_register
 - Auto-register shared entities to the connectors during connector realization, HM binary import, solver deck import and FE absorb.
 - sharedent_cleanup_delete
 - Cleanup shared entities during connector+FE deletion.
 - sharedent_cleanup_unrealize
 - Cleanup shared entities during connector unrealization.
 - value
 - 0 - Turn off
To turn on auto-registration:
*CE_SetGlobalSharedEntitySettings "auto_register" 1
   # Handle error
}Version History
2017.1
