hm_ce_getglobalsharedentitysettings
Gets the global shared entity management settings.
hm_ce_getglobalsharedentitysettings setting
HyperMesh Tcl Query Command
Gets the global shared entity management settings. These settings affect the shared entity management auto-registration process and the shared entity cleanup process during various operations.
setting
The name of the setting to query. See *CE_SetGlobalSharedEntitySettings for a list of valid settings.
To get the value of the auto_register setting:
hm_ce_getglobalsharedentitysettings "auto_register"
   # Handle error
Version History
2017.1
