hm_writeviewcommands
Sets the state of writing certain view commands to the command file.
hm_writeviewcommands mode
HyperMesh Tcl Query Command
Sets the state of writing certain view commands to the command file. The following commands are affected:
  • *rotateabout
  • *view
  • *view_restoreprevious
  • *viewset
  • *window
mode
0 - Do not write these commands to the command file
1 - Write these commands to the command file
To disable writing the view commands to the command file:
hm_writeviewcommands 0
   # Handle error
Version History
14.0
