hm_morph_getmvoledge
Returns the morph volume edge ID for the specified nodes along the edge.
hm_morph_getmvoledge node_1_id node_2_id
HyperMesh Tcl Query Command
node_1_id
The ID of the first node on the edge.
node_2_id
The ID of the second node on the edge.
To find the edge running through nodes with IDs 5 and 8:
hm_morph_getmvoledge 5 8
   # Handle error
Version History
11.0
