hm_ce_mesh_imprint_option_set
Sets a mesh imprint option value.
hm_ce_mesh_imprint_option_set name value
HyperMesh Tcl Query Command
name
Valid names are:
avoid_imprint - If enabled, create patches and resolve conflicts, skip mesh imprint.
avoid_int_snapping - If enabled, avoid snapping in meshing side.
keep_snap - If enabled, do snapping during patch creation.
skip_imprint - If enabled, just create patches, skip mesh imprint.
skip_overlap_check - If enabled, skip conflict checks.
strict_imprint - If enabled, any conflict causes an error.
value
The value of the option, 0 or 1.
To set the value of avoid_imprint to 1:
hm_ce_mesh_imprint_option_set avoid_imprint 1
   # Handle error
Version History
11.0.101
