hm_getlist
Returns an ordered list of entities from an entity list.
hm_getlist entity_type list_id ?panel_sensitive? ?model_name?
HyperMesh Tcl Query Command
entity_type
The type of entity list to query. Valid values are elems, laminates, lines, nodes, plies and surfs.
list_id
The ID of the list to query. Valid values are 1 and 2.
panel_sensitive
Can be used when multiple panel levels have been pushed, either using the shortcut function keys, or the hm_pushpanel command. This option determines whether to use the current panel or the previous panel for the operation. This option is relevant only when the list has been created from a panel entity selector under the above conditions. Valid options are:
  • 0 - Use the previous panel (default).
  • 1 - Use the current panel.
model_name
The optional model to get the list from. If not specified, the current model is used.
Examples
To create a line from a user specified list of nodes:
*createlistpanel nodes 1 "Select nodes for the line:"
set node_list [ hm_getlist nodes 1 ];
if { ! [ Null node_list ] } {
*linecreatefromnodes 1 0 150 5 179
To create, query, and clear a list from nodes 2, 10, and 3 for model model-2:
*createlist nodes 1 "by model" model-2 2 10 3
set my_list [hm_getlist nodes 1 0 model-2]
*clearlist nodes 1 "by model" model-2
   # Handle error
Version History
2020 - Added new option model_name.
