hm_formnodelistsfrommark
Forms ordered node lists from a mark of nodes.
hm_formnodelistsfrommark entity_type mark_id ?error_mark_id? ?use_edge_topo?
HyperMesh Tcl Query Command
The return consists of a list-of-lists, with each sub-list being an ordered node list.
- entity_type
 - Must be set to nodes.
 - mark_id
 - The ID of the mark containing the input nodes. Valid values are 1 and 2.
 - ?error_mark_id?
 - The ID of the mark to use for storing any nodes which cannot be formed into a list. Valid values are 0 (default, do not store), 1 and 2.
 - ?use_edge_topo?
 - 0 - Do not use the edge selection from the last call to *createmarkpanel for nodes.
To form node lists from nodes selected by the user via *createmarkpanel:
*createmarkpanel nodes 1 "Select nodes to form lists"
hm_formnodelistsfrommark nodes 1
   # Handle error
}Version History
14.0.120
