hm_getsolidshelloverlapinfo
Returns information regarding proximity overlap between one/more solid cavity element(s) and structural components.
hm_getsolidshelloverlapinfo source_entity_type source_mark_id target_entity_type target_mark_id maxproximitydistance
HyperMesh Tcl Query Command
Returns information regarding proximity overlap between one or more solid cavity elements and structural components (2D mesh). For each cavity (source components), the command returns the cavity surface area, the cavity volume, and the proximity overlap area per structural component (target components) in the following format:
{<solid1_compid> <solid1_surfacearea> < solid1_volume> {{<overlapshell1_compid> <proximity_area_with solid1>} {<overlapshell2_compid> <proximity_area_with solid1>}}}
source_entity_type
The type of source entity. Currently supported for components. Only 3D elements are considered.
source_mark_id
The ID of the mark containing the source entities. Valid values are 1 and 2.
target_entity_type
The type of target entity. Currently supported for components. Only 2D elements are considered.
target_mark_id
The ID of the mark containing the target entities. Valid values are 1 and 2.
Maximum proximity distance below which the overlap is calculated.
Examples
To get overlap information between component 20 and components 2, 10, and 13 for a proximity distance of 5.0:
*createmark comps 1 20
*createmark comps 2 2 10 13
hm_getsolidshelloverlapinfo comps 1 comps 2 5.0
   # Handle error
Version History
2021.2
