hm_comparegetdistance
Returns the distance value for a specific distance index.
hm_comparegetdistance distance_index
HyperMesh Tcl Query Command
Returns the distance value for a specific distance index. This must be preceded by a call to a relevant hm_compareentities* command and hm_comparefinddistances.
distance_index
The index of the distance to query, starting with 0. The number of distances can be found using hm_comparegetdistancecount.
To find the distance value for distance index 0 for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
hm_comparefinddistances 1.0 1
set distance [hm_comparegetdistance 0]
hm_compareend
   # Handle error
Version History
12.0
