hm_jobs_getServerDetails
Returns the name, IP and port of a server.
hm_jobs_getServerDetails name
HyperMesh Tcl Query Command
Returns the name, IP and port of a server. If the server does not exist, nothing is returned.
name
The name of the server to query.
To query the server named HWUL:
hm_jobs_getServerDetails HWUL
   # Handle error
Version History
14.0.130
