hm_wadlinessetparameters
Sets basic parameters for a WAD lines analysis.
hm_wadlinessetparameters side_angle front_angle spacing rear_reference_radius reference_resolution upper_bumper_angle lower_bumper_angle corner_angle
HyperMesh Tcl Query Command
side_angle
The angle used to determine the side reference line (default 45.0).
front_angle
The angle used to determine the front reference line (default 50.0).
spacing
The distance between section cuts used to determine the WAD lines and reference lines (default 100.0).
The size of the ball rolled along the windshield to find the rear reference line (default 100.0).
The spacing between cross-sections used to determine the reference lines (default spacing/2).
upper_bumper_angle
The angle used to determine the upper bumper reference line (default 20.0).
lower_bumper_angle
The angle used to determine the lower bumper reference line (default 25.0).
corner_angle
The angle used to determine the corner reference lines (default 60.0).
To setup and extract WAD lines data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesend
   # Handle error
Version History
12.0.110
