hm_marklength
Returns the number of entities on the specified mark.
hm_marklength entity_type mark_id ?panel_sensitive?
HyperMesh Tcl Query Command
This command returns the number of entities on the specified mark.
entity_type
The type of entity mark to query.
mark_id
The ID of the mark. Valid values are 1 and 2.
panel_sensitive (optional)
Can be used when multiple panel levels have been pushed, either using the shortcut function keys, or the hm_pushpanel command. This option determines whether to use the current panel or the previous panel for the operation. This option is relevant only when the mark has been created from a panel entity selector under the above conditions. Valid values are:
0 - Use the previous panel (default).
1 - Use the current panel.
To count the components on mark 2:
hm_marklength comps 2
   # Handle error
