hm_ce_getconfigfromconnectorcontrol
Gets the FE config name from a connector control or connector control default.
hm_ce_getconfigfromconnectorcontrol entity_type name
HyperMesh Tcl Query Command
entity_type
The type of entity to query. Valid values are connectorcontrol and connectorcontroldefault.
name
The name of the entity to query.
Examples
Get the FE config name from connectorcontroldefault rbe3_(load_transfer)_spot_nastran_template:
set fe_config [hm_ce_getconfigfromconnectorcontrol connectorcontroldefault "rbe3_(load_transfer)_spot_nastran_template"]
   # Handle error
Version History
2021
