hm_ispointinsidesolid
Checks whether a point is inside the volume of a solid geometry.
hm_ispointinsidesolid x y z solid_id
HyperMesh Tcl Query Command
This command returns 1 if the point is found to be inside the solid, -1 if the point is outside the solid and 0 if the point is on the solid’s boundary.
x
y
z
The (x,y,z) coordinates of the point.
solid_id
The ID of the solid geometry.
To check whether the point with coordinates 10, 20, 30 is inside the solid with ID 1:
hm_ispointinsidesolid 10 20 30 1
   # Handle error
