hm_removedieattribute
Removes the die attribute from an entity.
hm_removedieattribute die_attribute entity_id
HyperMesh Tcl Query Command
die_attribute
Valid values are:
addendum
binder
fl
tl
entity_id
The ID of the entity.
To remove the die attribute from the binder with ID 100:
hm_removedieattribute binder 100
None.
Version History
11.0
