hm_getnodeinitialcoords
Returns the node position on the initial associated geometry.
hm_getnodeinitialcoords node_id
HyperMesh Tcl Query Command
Returns the node position coordinates on the initial associated geometry. If a node does not have any initial geometry association, the command returns an empty list.
node_id
The ID of the node.
To get the x, y, z coordinates of the initial position of node 1:
hm_getnodeinitialcoords 1
   # Handle error
Version History
2021.2
