hm_getlinetangentatcoordinate
Returns the closest point, the components of the tangent vector and the angle between the tangent vector and the z-axis at the point on the line closest to the input coordinates.
hm_getlinetangentatcoordinate line_id x y z
HyperMesh Tcl Query Command
Returns the closest point, components of the tangent vector and the angle between the tangent vector and the z-axis at the point on the line closest to the input coordinates.. The first 3 return values are the closest point coordinates, the next 3 are the tangent vector components, and the last return value is the angle.
line_id
The ID of the line.
x, y, z
The (x,y,z) coordinates of the point.
To get the components of the tangent vector and the angle between the tangent vector and the z-axis nearest the coordinates (100,50,25) for the line with ID 341:
foreach {x y z tg_x tg_y tg_z ang}[hm_getlinetangentatcoordinate 341 100 50 25{}
   # Handle error
Version History
12.0.110
