hm_getincludeisolationentitiesmark
Returns the entities referenced/cross-referenced by the selected components, for include file organization purposes.
hm_getincludeisolationentitiesmark input_mark_id output_mark_id isolate_special reserved
HyperMesh Tcl Query Command
- input_mark_id
 - The ID of the input mark containing the components. Valid values are 1 and 2.
 - output_mark_id
 - The ID of the output mark that should contain the related entities. Valid values are 1 and 2.
 - isolate_special
 - A flag indicating whether to force isolation of individual mass, rigid or joint elements containing only isolated nodes.
 - reserved
 - Reserved for future use. Should be set to 0.
To put the entities related to components 1 and 2 onto mark 2:
*createmark comps 1 1 2
 hm_getincludeisolationentitiesmark 1 2 0 0
   # Handle error
}Version History
11.0.101
