hm_getmodelcheckcheckstatus
Returns the status for a given check.
hm_getmodelcheckcheckstatus check_display_name
HyperMesh Tcl Query Command
  • 0 - Check is not run
  • 1 - Check is run and there are failed entities
  • 2 - Check is run but there are no failed entities
  • 3 - Relevant entities to run the check are not present in the model
check_display_name
The GUI display name of the check. This is case sensitive.
Examples
To get the status for the "Unused materials" check:
hm_getmodelcheckcheckstatus "Unused Materials"
   # Handle error
Version History
2019
