hm_defaultstatus
Returns the default status of an attribute.
hm_defaultstatus entity_type entity_name_or_id attribute_name searchType
HyperMesh Tcl Query Command
entity_type
The type of the queried entity.
entity_name_or_id
The name or ID of the queried entity.
attribute_name
The name of the attribute.
searchType
By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. The two options are:
-byname: search only by name
-byid: search only by ID
If the attribute is set to the default value (grayed out in the card previewer), the function returns 1; otherwise, it returns 0.
None.
