hm_getmodelcheckcorrectionname
Returns the function for a given correction.
hm_getmodelcheckcorrectionname correction_display_name
HyperMesh Tcl Query Command
The GUI display name of the correction. This is case sensitive.
Examples
To get the function for the "Delete unused materials" correction:
hm_getmodelcheckcorrectionname "Delete unused materials"
   # Handle error
Version History
2019
