hm_exportoptimizationcards
Exports a Radioss optimization file.
hm_exportoptimizationcards type filename export_template
HyperMesh Tcl Query Command
type
The type of file to write:
1 - Export optimization file only
filename
The full path and filename of the output optimization file (*.radopt). Paths with spaces must be enclosed in quotes.
This can also be the Starter file name, or the Engine file name. The optimization file name is derived from this name.
export_template
The full path and filename of the optimization export template. Paths with spaces must be enclosed in quotes.
Examples
To export the optimization file, deriving the name from the model file C:/my_files/model_0000.rad:
hm_exportoptimizationcards 1 "C:/my_files/model_0000.rad" "[hm_info -appinfo SPECIFIEDPATH TEMPLATES_DIR]/feoutput/radioss/optientities.blk"
   # Handle error
Version History
2019
