hm_getidpoolnumber
Returns the ID pool number for a given solver and ID pool name.
hm_getidpoolnumber solver_id pool_name
HyperMesh Tcl Query Command
solver_id
The solver template ID. If set to 0 the current template is used.
pool_name
The solver pool name to query.
To get pool number of LS-DYNA element ID pool ELEMENT_SOLID_IDPOOL:
hm_getidpoolnumber 9  ELEMENT_SOLID_IDPOOL
   # Handle error
Version History
14.0.120
