hm_compareentitiessymmetry
Generates comparison results for entities positioned symmetrically about a plane.
hm_compareentitiessymmetry source_entity_type source_mark_id target_entity_type target_mark_id tolerance normal_x normal_y normal_z base_x base_y base_z ?result_type? ?review_results?
HyperMesh Tcl Query Command
Generates comparison results for entities positioned symmetrically about a plane. This must be preceded by a call to hm_compareinit.
These results can then be queried using hm_compareget* APIs, or written to a file using hm_comparewrite* APIs.
- source_entity_type
 - The type of source entity. Valid values are surfs or elems.
 - source_mark_id
 - The ID of the mark containing the source entities. Valid values are 1 and 2.
 - target_entity_type
 - The type of target entity. Valid values are surfs or elems.
 - target_mark_id
 - The ID of the mark containing the target entities. Valid values are 1 and 2.
 - tolerance
 - The tolerance value to use for the comparison.
 - normal_x
 - X-coordinate of symmetry plane normal direction.
 - normal_y
 - Y-coordinate of symmetry plane normal direction.
 - normal_z
 - Z-coordinate of symmetry plane normal direction.
 - base_x
 - X-coordinate of symmetry plane base location.
 - base_y
 - Y-coordinate of symmetry plane base location.
 - base_z
 - Z-coordinate of symmetry plane base location.
 - result_type
SURFS to SURFS SURFS to ELEMS ELEMS to SURFS ELEMS to ELEMS 0 - Basic Matched (paired)
Unmatched
Matched (paired)
Unmatched
Matched
Unmatched
1 - Full (default) Matched (paired)
Overlapped
Intersected
Unmatched
Matched (paired)
Overlapped
Intersected
Unmatched
Matched
Overlapped
Intersected
Unmatched
2 - Detailed Matched (paired)
Overlapped (paired)
Intersected (paired)
Unmatched
Matched (paired)
Overlapped (paired)
Unmatched
Matched
Overlapped
Intersected
Unmatched
 - review_results
 - 0 - Do not automatically show the graphical comparison results after execution.
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiessymmetry surfs 1 surfs 2 0.1 0 1 0 0 50 0 2 0
hm_comparewriteresults C:/temp/my_compare.txt
hm_compareendErrors
   # Handle error
}Version History
12.0
