hm_getsolverid
Returns the solver ID and pool name for the specified HyperMesh internal ID.
hm_getsolverid entity_type entity_name_or_id ?search_type?
HyperMesh Tcl Query Command
Returns the solver ID and pool name for the specified HyperMesh internal ID. If there is no solver ID and pool for the specified entity, an error is returned.
- entity_type
 - The type of entity to query.
 - entity_name_or_id
 - The internal ID or name of the entity to query.
 - search_type
 - By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
Examples
To get the solver ID and pool name for property with internal ID 4:
hm_getsolverid props 4
      or
hm_getsolverid props 4 -byid
      To get the solver ID and pool name for a material with name 1:
hm_getsolverid mats 1
      or
hm_getsolverid mats 1 -byname
   # Handle error
