hm_getsolvercards
Returns a list of solver cards (template tags) for either the specified entity type or solver ID pool.
hm_getsolvercards entity_type -byentitytype
or
hm_getsolvercards id_pool ?search_type?
HyperMesh Tcl Query Command
This command returns a list of solver cards (template tags) for either the specified entity_type or id_pool. The syntax is different depending on the method chosen.
If entity_type is specified, this command returns a list of all solver cards related to the specified entity_type. The specified entity_type must be the fully qualified HyperMesh entity name (see hm_getentitybasename) In this method the -byentitytype flag must be specified otherwise the command will treat entity_type as id_pool.
If id_pool is specified, this command returns a list of all solver cards related to the specified id_pool. The optional search_type argument determines whether id_pool is specified as a pool name or a pool ID. Valid values for search_type are -bypoolid and -bypoolname. If search_type is not specified, it defaults to -bypoolid. This method is only applicable to templates that support ID pools.
Examples
To get the solver cards for properties:
hm_getsolvercards properties -byentitytype
To get the solver cards for the ID pool with ID 1:
hm_getsolvercards 1
or
hm_getsolvercards 1 -byid
To get the solver cards for the ID pool with name one_idpool:
hm_getsolvercards one_idpool -bypoolname
   # Handle error
