hm_ce_getthickness
Gets the total number of layers to be connected.
hm_ce_getthickness ce_id
HyperMesh Tcl Query Command
ce_id
The ID of the connector.
To find out if the definition at the connector is 2T/3T/nT:
set ce_id [ hm_entitymaxid CONNECTORS];
set T [ hm_ce_getthickness $ce_id ];
The total thickness will influence the number of welds created at a connector.
