hm_wadlinesgetadulttestzone
Returns the coordinates of the adult test zone boundary.
HyperMesh Tcl Query Command
This must be run after hm_wadlinesinit and setting all necessary options with hm_wadlinessetparameters.
None.
Examples
To setup and extract the adult test zone:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
set zone_vertices [hm_wadlinesgetadulttestzone]
hm_wadlinesend
   # Handle error
Version History
2021
