hm_proximityend
Clears the proximity calculation data and memory.
hm_proximityend
HyperMesh Tcl Query Command
This must be preceded by a call to hm_proximityinit.
To calculate the proximity between all comps using a max distance of 2.5 and to query the component pairs:
*createmark comps 1 all
hm_proximityinit comps 1 2.5
set comp_pair_count [hm_proximitygetcomponentpaircount]
for {set i 0} {$i < $comp_pair_count} {incr i} {
    set comp_pair [hm_proximitygetcomponentpair $i]
    puts "Component pair $i: $comp_pair"
    set elem_pair_count [hm_proximitygetcomponentelementpaircount $i]
    for {set j 0} {$j < $elem_pair_count} {incr j} {
        set elem_pair [hm_proximitygetcomponentpair $i $j]
        puts "    Element pair $j: $elem_pair"
hm_proximityend
None.
Version History
14.0
