hm_setmodelcheckcorrectionstatus
Sets the applied status for the specified Model Check correction display name.
hm_setmodelcheckcorrectionstatus display_name display_name_correction status
HyperMesh Tcl GUI Command
display_name
The check display name.
The correction display name.
status
  • 0 - Not applied
  • 1 - Applied
  • 2 - Partially applied
To set the applied status for the check named "Unused Materials" and correction named "Delete Unused Materials" to applied (1):
hm_setmodelcheckcorrectionstatus "Unused Materials" "Delete Unused Materials" 1
   # Handle error
Version History
11.0.101
2019 - Added new status value 2.
