hm_comparegettransformationcount
Returns the number of transformations found.
HyperMesh Tcl Query Command
Returns the number of transformations found. This must be preceded by a call to a relevant hm_compareentities* command.
Multiple transformations can be found by hm_compareentitiesrecursive, hm_compareentitiesrotate and hm_compareentitiestranslate. Other hm_compareentities* commands only find a single transformation between source and target entities.
To find the number of transformations for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
set num_transformations [hm_comparegettransformationcount]
hm_compareend
   # Handle error
Version History
12.0
