hm_getelementnormal
Returns the normal vector of the specified element vertex/edge/face.
hm_getelementnormal element_id query_type query_index
HyperMesh Tcl Query Command
- element_id
 - The ID of the 2D/3D element to query.
 - query_type
- vertex - query_index is the index of a vertex (node) of a 2D/3D element.
 - edge - query_index is the index of an edge of a 2D element.
 - face - query_index is the index of a face of a 3D element.
 - query_index
 - The index of the vertex (node), edge or face. The index is 1-based and is ordered the same as the nodes/edges/faces defining the element.
Examples
To get the normal of shell element 100 edge index 1:
hm_getelementnormal 100 edge 1
      To get the normal of solid element 300 face index 2:
hm_getelementnormal 300 face 2
   # Handle error
}Version History
14.0
