hm_ce_cfglistget
Returns info on FE configurations for a specified solver, connector style and FE config file.
hm_ce_cfglistget solver_name style_name filename
HyperMesh Tcl Query Command
solver_name
The name of the solver to query. Examples include nastran, abaqus, lsdyna, etc.
style
The connector style name. Valid values are area, bolt, mass, seam and spot.
filename
The full path and filename of the FE config file. If not specified, the current.
Examples
To get the FE config list for Nastran spot connectors from the file C:/temp/feconfig.cfg:
hm_ce_cfglistget nastran spot C:/temp/feconfig.cfg
To get all current FE configs for Nastran spot connectors:
hm_ce_cfglistget nastran spot ""
   # Handle error
Version History
13.0
